LT77 remote bushes
Posted: Mon Mar 05, 2007 6:15 am
by minorv8
What is the function of the rubber bushes, reduce noise and vibrations ?
Is it possible to bolt it solid to the casing ?
Posted: Mon Mar 05, 2007 1:49 pm
by ian.stewart
You can remove the bushes, but must be obviously replaced with with a different material, I made mine from Alluminium, you must loctite all the bolts, I seemed to spend more time under the car putting new bolts back into the remote.
Posted: Mon Mar 05, 2007 5:28 pm
by ihatesissycars
Rimmer bros do a polybush kit for the remote which pretty much removes all movement it had with the rubber ones.
I have them fitted to mine and they're pucka!
Posted: Mon Mar 05, 2007 5:49 pm
by minorv8
I have no bushes at all and since I have a lathe and loads of aluminium I was planning to machine a set. Since the box in on the garage floor there will be no problems fitting the bushes. Thanks for the replies.
