Knocking on 4.2 in RR Classic Help!!!!!!!
Posted: Sat Aug 28, 2010 2:44 pm
Hi All
Hoping someone here has some more ideas as we are running out fast...
We have a knocking sound very much like top end noise probably more evident on the nearside of the car than the offside.
We have so far: changed the cam (for new standard cam), cam followers for new hydraulic ones, changed the timing chain and gears. swapped in second hand pushrods and rocker shafts from a (before total loss of compression following overheating) working engine. swapped all the ignition, HT leads, plugs, cap, etc. Taken the heads off and opened up the pushrod holes in the head (there is some marking on the removed pushrods to suggest that they may have been hitting the head). and done one hell of a lot of head scratching (ours not the cars?)
And yet the noise is still there!
We have also been over the whole engine, bellhousing and front end of the gearbox with the stethoscope, and still come back to the nearside head area as the most evident.
I have also bought new pushrods, but these seem to be the heavy duty rods and are fatter than the standard ones.
Gut feeling is that the pushrods are still hitting the heads, we have thought about putting the new pushrods in, but are concerned that if the ordinary pushrods hit the head, the fatter ones are going to hit much more severely and may do damage.
There is little difference on load or off load, but the noise is only present once the engine has warmed up. The noise is more noticeable behind the engine than in front.
We have not changed the cam bearings, but there is no obvious signs of excessive wear on the bearings,as far as I can see, on the removed camshaft. (the lobes have definitely seen better days)
We even suspected the flex plate as this engine is mounted to an autobox and there were reports that this could be a similar type of noise. but we have removed the bell housing cover and, as best we can without as yet removing the engine, inspected the flexplate, torque converter and flywheel.
If anyone has any thoughts about this, they would be very much appreciated.
Andy
Andy
