Hello Dave. Rover said:
Problem: Fuel vaporization can occur at the injectors when a vehicle with the engine at warm to hot operating temperature is parked in the sun for a short period and then restarted. Should a customer complaint of this nature be experienced, the following action should be taken.
Solution: Provision has been made for the fuel pressure to be increased temporarily during engine starting and for a short period of operation after engine start-up. As this effect would be undesirable if it occurred at every engine starting cycle, provision has also been made for it to only apply when the engine is at a high operating temperature.
Interested? Get the story how to do that
here. Contains "point to point" wiring instructions, but only an un-verified circuit diagram. Keep in mind Rover designed this solution to overcome age-related deterioration with the Efi system and there is a potential alternative route. Return the Efi System to "as new" condition, taking into account the different fuels currently available (low RON, unleaded), therefor looking closely at ignition timing as well as the Efi set-up.
A good place to start, the 15 point Efi Health Check specified
here: All the Efi components referenced in the Health Check program are described in
this archive., plus, a copy of the Efi Ops Manual would also help!
There are some work-arounds.
# Auto car solution, Car in gear, turn the ignition to crank, car wont start but fuel pump runs to purge the vaporised fuel from the fuel rail.
# On a Manual car, disconnect the White engine harness multiplug below the coolant expansion tank, crank, engine will not start but the pump runs as described above. Reconnect multiplug and crank.
# Fit a fuel pump "run switch" to do the same, before cranking.
# If not inconvenient, raise the bonnet and wait for the engine to cool.
