line locks
Posted: Sat Jun 05, 2010 12:55 pm
by JJMclure
this has probably been asked already but if you have a line lock like this one-
and you're using a dual master cylinder arrangement can you use it to block off the rears and just hold the brake pedal to burn out?
Posted: Sat Jun 05, 2010 7:16 pm
by topcatcustom
Thats what I was going to do in the near future, not ideal in a manual as you have to be quick on the pedals but cant see it being a problem with an auto box!
Posted: Sat Jun 05, 2010 9:16 pm
by Paul B
topcatproduction wrote:Thats what I was going to do in the near future, not ideal in a manual as you have to be quick on the pedals but cant see it being a problem with an auto box!
I've heard that you can lock ON the front brakes, with the ball valve in the
front brake line, push hard on brake, close valve, release brake, and then have both feet free to play pedals with.
Unless it slips mid burnout though.....
Posted: Sat Jun 05, 2010 9:20 pm
by topcatcustom
I had thought of that- but I have seperate feeds to each of the front brakes which makes it a pain in my case...
Posted: Sat Jun 05, 2010 9:55 pm
by bones
Ive got one of those fitted to my sd1 between the master and pressure valve, to hold the front brakes though. How come people go for holding the fluid away from the rear brakes??
rich
Posted: Sun Jun 06, 2010 6:10 am
People lock the rears off and leave the peddle active so you can allow the car to creep forward in the burn out box if there is too much water to allow the tyres to heat as quickly as you want. Also gives you an opportunity to do a big show-off burn out right up to the staging area.
Posted: Sun Jun 06, 2010 1:28 pm
by Paul B
kiwicar wrote:Hi
Ah, the old 'rolling burnout', looks far more impressive than sitting on the same spot and smoking them. Same with bikes.
And the track owner prefers you not to tear up chunks of track too.
