head rebuilding
Posted: Thu Apr 22, 2010 8:50 am
by POAH
I've bought some cheap heads (£15) off ebay to learn how to rebuild etc. do I need any specific tools to disassemble and reassemble them. any advice about taking apart and rebuilding would be great too.
Ross
Posted: Thu Apr 22, 2010 9:32 am
About the most usefull piece of kit is a press for getting the guides out and in again (don't bash them out witha hammer, odds on you will crack the port roof) also esential for fitting seats. If you are porting the heads a nice chunky pillar drill is handy for opening the throat area consistantly across all the ports. A set of seat cutters for hardened seats. Really it depends on what you are aiming to achieve.
Posted: Thu Apr 22, 2010 10:20 am
And if you're not porting, just some wire brush type things to clean it all up, and a scraper.
Posted: Thu Apr 22, 2010 11:49 am
by topcatcustom
How would you use the pillar drill Mike?
Posted: Thu Apr 22, 2010 12:05 pm
Hi Tom
to open out the throats with the seats out you use a cutter mounted in a mandral with one end in the chuck of the pillar drill, the other end in the guide so it is centred and nice and solid, the profile of the throat is ground into the cutter. When you have put the seats back in you can open the seats out using a grinding attachment again with the guide centering the mandral the grinder is attached to and the pillar drill driving the grinder attachment. Finally seat cutting attachments for hardened seats work the same way with a shaped stone driven from a chuck. It can be done with a normat electric drill but is much more accurate with a pliiar drill.
Posted: Thu Apr 22, 2010 1:12 pm
by topcatcustom
Gotcha 8)
Posted: Thu Apr 22, 2010 1:45 pm
by POAH
Hi mike
I'd just like to be able to take the heads apart, clean them up and refit them. They are not going to go on my engine just wanted to be able to rebuild a head.
Ross
kiwicar wrote:Hi
Posted: Thu Apr 22, 2010 1:52 pm
by topcatcustom
The only things you "take apart" would be lifting the rockers off which just have 5 bolts per head, and taking the valve asemblies out, for which you need a valve spring compressor. Apart from that they are just big funny shaped lumps :lol:
Try some oven cleaner to clean them up, works pretty well.
Posted: Thu Apr 22, 2010 1:54 pm
by CastleMGBV8
Ross,
In that case all you need is a decent valve spring compressor, I prefer the screw type with length adjustment, then it will fit almost any head.
http://www.machinemart.co.uk/shop/searc ... any/page/1
Kevin
Posted: Thu Apr 22, 2010 2:22 pm
by POAH
topcatproduction wrote:The only things you "take apart" would be lifting the rockers off which just have 5 bolts per head, and taking the valve asemblies out, for which you need a valve spring compressor. Apart from that they are just big funny shaped lumps :lol:
still never done it before. once I've cleaned them up and got some money I'll have a go at porting them for a laugh
Posted: Thu Apr 22, 2010 3:13 pm
Personally I like this type http://cgi.ebay.co.uk/DRAPER-UNIVERSAL- ... 4aa0815315
or even simpler ones that use the rocker shaft as the fulcrum, quick precise and after 16 you dont feel as if you have unscrewed your wrist :shock: :lol: .
Posted: Thu Apr 22, 2010 4:56 pm
by spend
kiwicar wrote:..quick precise and after 16 you dont feel as if you have unscrewed your wrist :shock: :lol: .
Am I missing something? you only need to adjust the screw to fit the heads you are working on, all 16 are just a case of clamping and unclamping I find.
Posted: Thu Apr 22, 2010 6:45 pm
Ah
you mean one of these
http://cgi.ebay.co.uk/200mm-8-Valve-Spr ... 20b02a48c8
not one of these
http://cgi.ebay.co.uk/valve-spring-comp ... 5636dceecd
:D
I still prefere the bar and hook type 8)
