Offenhauser Manifold with Edelbrock Carb
Posted: Sun Mar 28, 2010 4:28 pm
by Simeon
As i've had to use the levelleing plate in between my Offenhauser manifold and edelbrock carp I need longer bolts. Could someone tell me what size they are?
Next question, there appears to be two holes on the manifold at each corner of the carb. I presume these are for fitting of different type carbs. do these additional holes need a bolt putting in them?
Posted: Sun Mar 28, 2010 4:55 pm
not sure of the bolt sizes, but they, being american, will be some unf or unc size, ie not metric.
the second bolt holes are as you suspect for different carbs, they only need blanking if they allow air into the manifold directly.
Posted: Sun Mar 28, 2010 6:02 pm
by ged
Threads are 5/16" UNC.
Posted: Sun Mar 28, 2010 6:28 pm
by sidecar
ged wrote:Hi,
In my humble it's worth getting long screws with a thread all the way up to the head. You can then cut the heads off, clean up the threads and make studs out of them. Use two nuts locked together to wind them into the manifold. Once done you have no more worries about stripped ali threads etc.
Pete
Posted: Mon Mar 29, 2010 4:23 pm
by Simeon
Thanks for your help all
Ged, top idea, will do
Posted: Mon Mar 29, 2010 8:36 pm
by ged
Hi Simeon,
I think you mean to thank sidecar. :lol:
Posted: Mon Mar 29, 2010 9:24 pm
by Simeon
Errrr yea sorry! thanks Sidecar :?
More to the point I've just noticed my Edelbrock Carp! on the first line. a new species of fish discovered on the V8 forum :lol: :lol: :lol:
Posted: Mon Mar 29, 2010 9:34 pm
by CastleMGBV8
Back in the 60's there were Fish carbs, very effective on Mini's
Kevin
Posted: Tue Mar 30, 2010 4:57 am
by sidecar
Simeon wrote:Errrr yea sorry! thanks Sidecar :?
No Problem!
I guess that your Edelbrock Carp is a type of "Metallic" Carp! :D
