1980 jag xj6 flapper air flow meter
Posted: Tue Mar 16, 2010 10:00 am
by richy
hi all,do any one no if xj6 flapper air flow meter will fit rover sd1 Vitesse,plug in and run,i have also noticed the Porsche 924 & 944 have the same meter, be glad for any help.thanks.richy
Posted: Tue Mar 16, 2010 4:22 pm
by bones
it has been done, just found an article on a sd1 and he fitted a xj6 airflow meter
rich
Posted: Tue Mar 16, 2010 8:51 pm
by Wotland
One of my friend will have soon for sale Jag afm and adjustable ecu for flapper RV8.
The afm is brand new.
Send me PM if you are interested
Posted: Thu Apr 08, 2010 9:57 am
by demo2
yes it does, i run one on my 5.0ltr.
Posted: Thu Apr 08, 2010 2:38 pm
The calibration will be different, so you need an adjustable ECU or accept non optimal running.
Posted: Thu Apr 08, 2010 3:59 pm
ChrisJC wrote:The calibration will be different, so you need an adjustable ECU or accept non optimal running.
I'm told you can alter the spring return pressure - so therefore the fuelling. Not tried it, though.
Jaycar do a digital gizmo that interfaces between AFM and ECU and allows you to programme the curve. Sounds just what's needed. I thought so and built one - but never got round to trying it as I went down the MegaSquirt route. Cheap enough to experiment with - and easier to reverse than playing about with springs.
Posted: Thu Apr 08, 2010 6:29 pm
Yes, it's easy to alter the spring pressure, however the actual curve is laser trimmed into the potentiometer tracks, and you can't change that.
So you could optimise it in one or two points of the curve by altering the spring, but it wouldn't be right on the other points. How far out it would be I don't know.
Also, the Jag AFM has a larger bore than the RV8 one, so the hoses don't fit.
Posted: Wed Apr 14, 2010 10:45 am
by richy
thanks every one for your reply.richy
