hi all ignition wiring help needed asap please...
Posted: Tue Feb 16, 2010 10:50 pm
by minor8pot
i have a 3.5 vittesse engine in my car with the dizzy with the amp on the side...and the plug...its running a 500 edel carb...does anyone have a diagram of what wires go where on the coil,and which ones are live and earth to the loom of the car...need asap please...
Re: hi all ignition wiring help needed asap please...
Posted: Tue Feb 16, 2010 11:11 pm
by DEVONMAN
minor8pot wrote:i have a 3.5 vittesse engine in my car with the dizzy with the amp on the side...and the plug...its running a 500 edel carb...does anyone have a diagram of what wires go where on the coil,and which ones are live and earth to the loom of the car...need asap please...
Hi. If it's a 2 pin module/amp the spade nearest the end of the module is the trigger and connects to the negative side of the coil. The other spade connects to ignition live 12v.
To clarify that, looking down on the module, the terminals form a T shape.
The top bar ot the T is the trigger and the vertical leg of the T is connected to 12v ign live,
Regards Denis
