4.0 windage tray?
Posted: Sun Feb 14, 2010 10:22 pm
by Paul V8
Hello,
I'm changing the engine in my car from a 3.5 to a 4 litre rover, the new engine doesn't have the drillings to take a SD1 windage tray, I think it's important to use 1. Is it ok to drill and tap threads into the new block?
Thanks for help.
Posted: Sun Feb 14, 2010 10:58 pm
by kstrutt1
Does it actually clear the 4.0 crank? worth checking before you drill holes etc.
Posted: Mon Feb 15, 2010 1:27 am
by ppyvabw
kstrutt1 wrote:Does it actually clear the 4.0 crank? worth checking before you drill holes etc.
It will do. It has the same stroke as the 3.5 and 3.9.
No problem at all, just drill and tap it. There's nothing there to damage.
As an aside, the 3.5s (The early ones at least) also had supports for the oil pick up attached to the fourth mains cap. 3.9s didn't have that, rather the oil pick up was held on solely with two scabby 1/4 unc bolts at its base.
Dunno about the 4L as that has a different oil system but the same applies, it should be supported at the end like the early 3.5s were.
Posted: Mon Feb 15, 2010 4:47 am
by 92rrrandall
I have installed the 3.5 windage tray on a 4.0 myself by drilling and tapping the holes.
I wonder how much of a difference a windage tray makes??
Randall
Re: 4.0 windage tray?
Posted: Mon Feb 15, 2010 2:54 pm
by DEVONMAN
Paul V8 wrote:Hello,
Thanks for help.
Hi. Don't drill too deep as the 4.0 cross bolts line through with some of the windage tray bolts.
Just out of interest, are you using the 4.0 sump /front cover and oil pick up pipe?
Regards Denis
Posted: Mon Feb 15, 2010 8:57 pm
by Paul V8
I'm using a new 4.0 short engine, SD1 sump, oil pump and front cover. Ported late type heads.
My 3.5 made 256bhp. Fingers crossed for the 4 litre.
