This is getting silly now
Posted: Sat Feb 13, 2010 5:04 pm
Guys im pulling my hair out, ive got what i suspect as an intermitten air leak.
Im using a twin plenum converted to hot wire - at idle theres no drama as it sits nicely at 900-1000rpm a blip of the throttle and it returns back as it should. Under load the revs will only go back to 1800 rpm.. then if i turn the engine off it goes back to idle at 900-100rpm.
Could this be as simple as a stepper motor issue?
The butterflys are shut tight and it appears the throttles not hanging up.
Before i strip it all down once again any ideas?
