sd1\lt77 racing clutches
Posted: Mon Jan 25, 2010 8:15 pm
by karrionchris
Just come back from the pod and after having some good runs my clutch decided to start giving up and slipping on burnouts and launches.
Im about the chuck in an LSD so i think i might need a stronger clutch. anyone have any ideas of a stronger clutch that will still fit in an LT77/sd1 bell housing. don't mind spending a bit of cash but i dont want to spend everything.
Posted: Mon Jan 25, 2010 8:18 pm
by ian.stewart
Have a look on the Helix web site, Im running a clutch supposedly good for 300hp.
http://www.helix-autosport.com/
Posted: Mon Jan 25, 2010 11:28 pm
by DEVONMAN
The Mcleod 10.5 unit from Real Steel is good but you have to either have your flywheel drilled for it or buy their steel flywheel. The Rover pressure plate version is a 2400lb assembly but the Chevy version is 2700 with the same bolt pattern.
Regards Denis
Posted: Tue Jan 26, 2010 5:48 am
by karrionchris
Brilliant
Do you know if that will fit in the standard 2wd lt77 bell housing
Posted: Tue Jan 26, 2010 7:41 am
by DEVONMAN
karrionchris wrote:Brilliant
Real Steel sell the Mcleod to fit the Rover bellhousing. The release system has to be in good condition as the clutch needs a bit more movement to release than the standard clutch.
Regards Denis
Posted: Tue Jan 26, 2010 6:32 pm
by bigaldart
What he said
