Page 1 of 2
manifold enquiry
Posted: Sun Nov 15, 2009 10:48 pm
by bones
Hi just a quick question, would rover p6 manifolds be ok to use with turbos, i thought i could turn them upside down and make plates to fit the turbos to??
Posted: Sun Nov 15, 2009 11:30 pm
by JSF55
Upside down ? they can be mounted to the front for clearence, but not upside down !
Posted: Sun Nov 15, 2009 11:49 pm
by bones
not the turbos , i thought about the manifolds being turned upside down and swapped over, so the flanges match
rich
Posted: Mon Nov 16, 2009 1:03 am
by kiwi303
nope... went and dug out my P6 and LR heads and P6 manifolds, won't fit. Now way, No how.
Posted: Mon Nov 16, 2009 1:31 am
by bones
i take it the p6 heads and exhaust ports and bolt patterns are a different to the sd1 heads then?
rich
Posted: Mon Nov 16, 2009 1:52 am
by ian.stewart
you can make them face forward or rearwards, but not upside down, There is a company offering cast turbo manifolds, cant remember who tho,
Posted: Mon Nov 16, 2009 4:56 am
by kiwi303
If you look at the heads, the bolts are on the top on one side, and the bottom on the other. Flip the manifolds back to front and they still line up, flip them upside down and the bolt holes on the manifolds and the heads, are on the same side, but at vertical opposites.
Posted: Mon Nov 16, 2009 11:51 am
if they bolt on....you can make em work.
but reversed pointing down is fine, then link them with a pipe etc
Posted: Mon Nov 16, 2009 12:44 pm
by bones
Thanks for the replies all, i was just being lazy and hoping i could get out of making some. Idid find some cast ones for turbos ,but to much money. Looks like i need some gas pipe instead, so with the turbos placed to the front of the engine with 1 pipe coming from the back exhaust port and the other 3 ports welded to it be ok??
rich
Posted: Mon Nov 16, 2009 1:08 pm
Posted: Mon Nov 16, 2009 3:10 pm
by bones
there the sought i was thinking of, thanks for that. I know forged pistons are best to use, but would standard low comp 3.9 pistons be ok for 500ish bhp if they were ceramic coated. Would like to use as much standard stuff as i can.??rich
Posted: Wed Nov 18, 2009 10:38 am
by bones
the 3.9 pistons are 8;13 to 1. i can get some cheap, but if there no good then forged it will have to be.
Posted: Wed Nov 18, 2009 12:05 pm
by topcatcustom
I think it depends on the boost Rich, not sure about ceramic coating- I'm still itching for someone to try cryogenic treated stuff to compare it to standard before treatment!
Posted: Wed Nov 18, 2009 12:17 pm
If the pistons are of decent construction, and do not have any oil control SLOTS, then they should be ok.
If they have slots...they're crap and will likely break very easily.
Posted: Wed Nov 18, 2009 12:35 pm
by bones
to be a pain
, the slots that you find in standard rover pistons??, better ring them and find out what they have in these ones
rich just rang and these have 2 slots in them, 1 either side above the gudgeon pin. They seem to think they would be ok for upto 5 bar. Thats not very high for twin turbos is it
rich
