Decisions! What would you do?
Posted: Tue Jan 30, 2007 4:40 pm
I at some point in the furutre (not immediately though as i'm now skint!) will be fitting my 4.6 crank into my interim block and i have two options.
1. Line bore the block and at the same time fit the cross bolts.
£180 machine work, £xx for the bolts and about £30 for the bearings.
Advantages, bigger + better main bearing size and cross bolted caps.
Disadvantages, cost (about £250+) and risk a fooked block if they bugger it up.
2. Turn the mains down to the smaller size of my 3.9 block and fit studs.
Advatages, CHEAP!
Disadvantages, smaller bearing size, no cross bolts (in the grand scheme of things they are considered better than studs on their own its just if i'm going to be pushing things enough to need that extra security) less pub ammo.
What would you choose?
Anything to add to those?
Advatages, CHEAP!
