Oil change?
Posted: Mon Aug 17, 2009 8:12 pm
by v8alex
I've been runnning my rebuilt 3.5 RV8 and have covered 300miles. As it's the first oil in the engine, should I be changing it now, or cover some more miles ?
Alex
Re: Oil change?
Posted: Mon Aug 17, 2009 8:58 pm
by adamnreeves
when I ran mine in I changed the oil after 20 minutes!
Not on the road yet but I would change the oil before 500 miles. Oil is cheap enough anyway.
v8alex wrote:I've been runnning my rebuilt 3.5 RV8 and have covered 300miles. As it's the first oil in the engine, should I be changing it now, or cover some more miles ?
Alex
Posted: Tue Aug 18, 2009 10:07 am
by RoverP6B
Hello Alex,
I second Adam's advise,..change prior to 500 miles.
Are you using 'running in oil'?
Ron.
Posted: Tue Aug 18, 2009 6:55 pm
by v8alex
Thanks folks - this weekends job then. I'll pass the oil through some filter paper with petrol to see what residue I'm left with.
I'm using Halfords classic motor oil - 20W50 I think.
Alex
Posted: Tue Aug 18, 2009 7:07 pm
by adamnreeves
Your oil filter would have trapped the smaller bits. Cut the top off the oil filter carefully trying not to get any swarf on the element. Then examine. Still examine oil in sump though as the large bits will be stopped by the oil pick-up. However I removed my sump to fix a leak and most of these bits remain stuck to the sump floor however I run a trap door and baffled sump.
v8alex wrote:Thanks folks - this weekends job then. I'll pass the oil through some filter paper with petrol to see what residue I'm left with.
Alex
