Haltech
Posted: Tue Aug 11, 2009 8:26 pm
by plank22
Has anyone used haltech managment on a rover 3.9 v8? If so opinions please................ta!
Posted: Wed Aug 12, 2009 3:09 am
by RoverP6B
Hello Plank,
Here is a link to a discussion on this topic at the Australian Land Rover Owner's forum.
http://www.aulro.com/afvb/technical-cha ... rchip.html
You might find it helpful.
Ron.
P.S : I was not one of the contributors.
Posted: Wed Aug 12, 2009 7:29 pm
Ive never used them on a Rover, but Haltech do make good ecu's
Which model were you thinking of using ?
http://forums.haltech.com/index.php
Posted: Wed Aug 12, 2009 7:37 pm
by plank22
cheers guys rele helpful, I have one with the loom all ready its a E6X. Its going in a land rover so all I want is a base map and perhaps a "live tune" as all I want is reliability rather than performance.
Posted: Wed Aug 12, 2009 7:47 pm
Ask over on the Haltech forum
Base map will be tricky, unless there is someone out there using the exact same setup, with same triggers and sensors etc
Posted: Wed Aug 12, 2009 7:57 pm
by plank22
was hoping for one just to get it running so as i can get it over to the tuning man to tweak it a little. This sound possible?
P.S just saw the vid of your garanny at pod, holy sh*t!!!
Posted: Wed Aug 12, 2009 9:14 pm
Anything is possible.
But in order for a guess map to get you started, you would need to gie very specific details about your setup.....
And TBH, if you knew enough of these details, you could work through and get it started yourself anyway.
Just follow through the instructions. It wont be that bad.
Posted: Wed Aug 12, 2009 10:25 pm
by plank22
ok its just I dont have a clue for mapping and know of plenty of people who think they do and what they have done could not have been more wrong! So kinda been scared off......
Posted: Fri Aug 14, 2009 5:52 pm
by kokkolanpoika
i have got haltech F10 with my ex 4,6 stage 3 engine.. and now it is my 5,2l unit..
I can give them to you, but not sure how, because i live in Finland.. And i think you need old computer witch has got "dos program" to read those maps? not sure, but i think?
Posted: Sat Aug 15, 2009 5:53 am
by minorv8
Timo,
I had no problems reading your maps, (my laptop has XP). However, I think I need to read the values manually from each map since the file format was not recognised by E6X. Then the values need to be inpit manually to E6X files. Some work yes but would give something as a start.
Plank22, F10 is fuel only and naturally does not have ignition maps. You need to source them somewhere. Haltech ECU does have a library of ignition maps that will get you started.
I have bought a Haltech E6X and plan to have it fitted in the wintertime. Exact components are still open but I am using Haltech supplied sensors. I have two sets of BMW Coopes S injectors that should be plenty enough for Rover. Sadly they are of shorter design so the rail needs modifying. Or then I just need to buy another set of injectors with correct dimensions.
Posted: Sun Aug 16, 2009 7:50 pm
by plank22
ok great thanks, any feedback at the mo it good as im kinda limited in info!
