Chevy 305 Emissions
Posted: Sun Jul 19, 2009 2:03 pm
by Stuball
Have a chevy 305 in an astro van, running a holley carb, standard distributor etc.
Failed MOT on emissions, High CO 5.9% but fairly low HC, 341ppm
Not sure if its running rich or not due to the low HC.
Any thoughts? (before i start fiddling)
cheers
Stuball
Posted: Sun Jul 19, 2009 3:57 pm
probably running rich but with quite alot of ignition advance enabling it to burn the HC to CO but not enough oxygen to burn the CO to CO2.
Posted: Sun Jul 19, 2009 6:45 pm
by Stuball
Cheers for that.
I am a bit unsure about the ignition timing.
Its set at 8 BTDC but with the vac advance connected.
With vac disconnected (pipe plugged) the engine refuses to start, so i wonder if the timing is completely out?
Stuball
Posted: Sun Jul 19, 2009 7:04 pm
by sidecar
Stuball wrote:Cheers for that.
Stuball
If your carb has a ported vac take off you could connect the vac canister up to that, I believe that this is more "normal" (At least from what I've read on the Cobra forum)
Also I think that the SBC boys run a bit more static advance than what you're running, maybe 14-18, 36 total.
As to the holley, well once the igintion us setup you could try slowly winding in all the pilot screws until the engine starts to slow down, then wind them out about 1/4 of a turn.
Make a note of the screw settings before you start fiddling!
I'm more of a Rover Bod so I could be talking crap (as normal!)
Pete
Posted: Sun Jul 19, 2009 7:48 pm
by Stuball
So should the timing should be set with the vac advance disconnected (and plugged)?
thanks again
Stuball
Posted: Sun Jul 19, 2009 8:01 pm
by sidecar
Stuball wrote:So should the timing should be set with the vac advance disconnected (and plugged)?
thanks again
Stuball
If the vac canister is connected to a "ported" port then it should not make any difference. However most people would disconnect it just to make sure that it does not mess up your settings.
Like I said though I'm more of a Rover Bod! Hopefully someone who knows about SBC's will help you out.
My lump does not even run a vac system, I run 12 static but with soft dizzy springs so all the advance is in my 2700 RPM. (32 total)
Pete
Posted: Mon Jul 20, 2009 10:07 am
by demo2
That wouldnt happen to be a purple astro van wud it, black leather interior?
Posted: Mon Jul 20, 2009 5:56 pm
by Stuball
Yeah that be the one demo2 :D (small world eh)
Back on the road after 2 and a half years
Stuball
Posted: Tue Jul 21, 2009 11:57 am
by demo2
I know that car very well, belonged to Vern, a good friend of mine. Used to have a 350 in, i stripped that 305 thats in it. I didnt even know he had sold it.
Posted: Tue Jul 21, 2009 8:24 pm
by Stuball
Yeah paul i know Vern.
I work with him :D
We might actually be able to dust his Cortina off now and get
it on the road :lol:
Stuart
Posted: Wed Jul 22, 2009 9:35 am
by demo2
The day that car hits the road will be a miracle,lol that rover aint run for 14 yrs!
Posted: Sat Jul 25, 2009 1:11 pm
by Stuball
Managed to solve the emissions, backfiring and stalling problems all at the same time today :D
Started again with the ignition timing, found that it was 12 degrees retarded with the vac advance disconnected :shock:
Reset the static timing to 10 degrees advanced, and its like a new engine 8-)
cheers for the help
Stuball
