Ignition Timing and Camshaft Duration
Posted: Fri May 29, 2009 1:13 pm
What role does camshaft duration play when setting the initial timing or is it completely indepedent?
Hypothetical.....Two engines, a 3.9 litre and a 4.6 litre. Both are fitted with post 1994 ten bolt heads. Each engine is running the same camshaft profile. The stroke volume is different between both units, and that is the only variable.
Given that the 4.6 require less total timing, that suggests that the larger engine is more efficient, thus the difference in stroke volume must be significant, but why?
Ron.
Ron.
