Drop base filter restriction
Posted: Fri May 01, 2009 9:17 pm
by Darkspeed
I have been taking a close look at the drop base filter thats fitted to the 390's on the two cars that I have and wondering how much of a restriction they are causing - on the Dutton the top of the filter is being dented by the float bowl breather the lid is that close.
On the G27 the Wildcat Spider manifold is quite a high rise a a nice deep filter will not fit under the bonnet - I have removed the bonnet bulge at the moment - but was hoping to refit but looking at this I really think that its causing a big restriction. A 3" filter or a flat base filter will means a significantly bigger bonnet hump.
My car does not run choke butterflys so I was considering taking the carb off and milling the choke horns off and doing some epoxy work to flow the carb entry.
Any thoughts on these issues?
Andrew
Posted: Fri May 01, 2009 10:03 pm
by CastleMGBV8
Andrew,
The minimal clearance to the lid on a dropped base filter does cause flow problems.
Whether you can modify the carb in the way suggest I don't know.
Real Steel are very knowledgable on Holley carbs, alternatively you could ask your question on the US British V8 Forum where they will have more information on the subject.
http://forum.britishv8.org/list.php?6
Alternatively you could fit a Top Hat to the carb with one or two remote cone type filters depending on your flow requirements.
Hope you get some answers.
