Modifying the inlet port on a carb head to suit injection
Posted: Wed Apr 22, 2009 11:29 pm
by BenL
I'm just in the process of fitting injection to a carb engine and the heads don't have the cutouts in the inlet port where the injectors go. I can see by assembly the manifold to the engine where they should go but am unsure as to the exact shape of the cutout. Can anyone help with a picture and or description.
Regards
Ben
Posted: Thu Apr 23, 2009 5:50 am
by Eliot
I dont think it has to be too precise. You are just trying to give the injector a better line of site into the inlet port.
Posted: Thu Apr 23, 2009 8:04 am
by CastleMGBV8
Ben,
Give me your e-mail address amd I'll send a couple of pics.
The composite valley gaskets has the indents that show where the heads need grinding
kevin.
Posted: Fri May 01, 2009 12:18 am
by HairbearTE
Take a close look at an LS1 'cathedral' inlet port. You might be able to actually improve on the real inj 3.9 heads (which only have a small cut-out for the injector spray) by giving the injectors a better shot at the valve ala LS1..
