Page 1 of 2
Fuel Injectors
Posted: Tue Mar 17, 2009 1:44 pm
by CastleMGBV8
I have a gems type manifold off a 4.0 Rover V8 and am wondering what the fuelling limit is of the standard injectors in respect of how much power they will support.
I am anticipating in the region of 270 BHP are they going to flow enough fuel?
Posted: Tue Mar 17, 2009 3:29 pm
by Wotland
Kevin,
I use this calculator : http://www.z31.com/software/injector.pl
Green Lucas and Bleu Bosch injectors flow around 180CC. Not enough for 275BHP.
Posted: Tue Mar 17, 2009 5:00 pm
by r2d2hp
I am using new low impedance 214cc injectors at 2.5 bar and am seeing 314bhp.
Am about to upgrade as duty cycle must be quite high.
Posted: Tue Mar 17, 2009 7:16 pm
by CastleMGBV8
Dimitri,
Thats a useful programme but am getting conflicting answers.
If i enter BSFC of 0.50 and duty cycle od 0.85 and injector flow rate of 180 it says they will only support 233 BHP
If I input the same figures but Power at 275 BHP it says the injectors are large enough unless I'm doing something wrong?
I have the green Lucas injectors.
Posted: Tue Mar 17, 2009 8:19 pm
by Wotland
Kevin,
I entered same figures as you and I had this :
Power: 275 horespower
Number of injectors: 8
BSFC: 0.50
Duty cycle: 0.85
This combination will require 212 cc/min injector (20.2 lbs/hour)
For the choice of injectors I use this data base : http://users.erols.com/srweiss/tableifc.htm
This site gives also some indications about the BSFC figure to use.
Posted: Wed Mar 18, 2009 12:38 am
by CastleMGBV8
Dimitri,
My mistake forgot to change the number of injectors.
So what would you recommend as it's not going to be cheap to change 8 injectors.
Posted: Wed Mar 18, 2009 7:21 am
by Wotland
Kevin,
I found more informations about genuine injectors : Standard spec is 185cc/min at 36PSI for 14CUX Lucas injectors. Bosch Thor injectors flow the same, but at 56PSI.
One option is to use Bosch 0280-150-561 rated at 230cc/min at 40 PSI.
Dimitri
Posted: Thu Mar 19, 2009 5:13 pm
by CastleMGBV8
Dimitri,
The green Lucas injectors I have are D1830GA buy I cannot find a spec for them are these the 14cux injectors you mentioned earlier rated at 185cc/min at 36PSI.
Bear in mind I'm a complete learner of EFI but if the standard injectors were run at a slightly higher pressure say 40lb ish would this help and increase flow rate pro rata by 10% as I would like to not have to buy a new set if possible?
I intend using a MS 1 V3 ECU does that allow adjustment of the duty cycle and could I realistically increase fuel pressure higher to say 43.5 PSI. I haven't bought a fuel pump yet as I want to be sure everything is compatable.
Posted: Thu Mar 19, 2009 5:52 pm
by r2d2hp
Hi Kevin
I believe D1830GA are Lucas and flow is 185cc/min at 36PSI. Was told they do not like increased pressure, not sure how true that is.
If your interested in a brand new set of low impedance 214cc bosch injectors which is what I use let me know as I have a spare set. You do need to run them with ballast resistors that cost a couple of pounds from Maplin or RS
regards
Reg
Posted: Thu Mar 19, 2009 5:57 pm
by Coops
i was running my old hotwire ones at 40-45psi with no probs,
but now using bigger injectors turned down,.
Posted: Thu Mar 19, 2009 6:03 pm
by CastleMGBV8
Tony,
I remember you got some new ones from the US, whats the spec, price and supplier please?
Posted: Thu Mar 19, 2009 6:28 pm
by Coops
bosch greenmotorsport ones,
440cc/min
fiveO on ebay US
doubt if they will be any good on current exchange rate mate.
Posted: Thu Mar 19, 2009 6:39 pm
by Coops
Posted: Thu Mar 19, 2009 6:46 pm
by Coops
Posted: Thu Mar 19, 2009 6:56 pm
by r2d2hp
42Ib injectors are good for best part of 600bhp :x
Think Kevin needs to be looking for injectors of around 20Ib
Read that over large injectors can cause all sort of running issues
