Airlock or what?
Posted: Sun Feb 22, 2009 7:40 pm
Rover V8; was 4.0 litre, now 5.0 litre. I suffered what I thought was a cracked liner last year and have replaced the block. I had my heads pressure tested before refitting.
The cooling system utilises a large radiator which is slightly lower than the top hose. The top hose has a filler cap at its highest point with a blank cap fitted. From this is a small bore hose expansion take-off to the expansion tank.
This hose enters the bottom of the tank and thus has a head of water. There is a 15 psi pressure cap built into the top hose, beyond the expansion take-off.
My symptoms last year were the same as I am experiencing now. I have fully bled the system. I have attached a pressure gauge to the top of the expansion tank. On starting from cold, pressure is seen to slowly build, reaching around 14 psi, which is around the time the fan cuts in at 88 degrees. As soon as this happens, pressure is seen to drop significantly. When the fan shuts off at 77 degrees, pressure rises again, and then drops when the fan kicks in, and so on.
If I release the pressure cap, and the refit whilst hot, and keep the engine running, pressure reaches around 5 psi before the fan kicks in and reduces it to around 1 psi.
I have sniff tested the system for HC’s which proved negative. The fact that exactly the same symptoms are occurring as on the old block suggests to me that this is not a cracked liner issue, however what is it?
I’m thinking that this is the mother of all air-locks, but where? I have fully purged the system.
Would fitting a bleed take-off to the header tank from the bottom hose, with the top air-bleed running into the top of the tank help in this situation and is it worth trying?
The system is very new, so no blockage issues and the radiator cools excellently, both with the fan and when running on the road.
Any ideas before I completely pull my hair out?!
