tvr 4ltr
Posted: Thu Jan 22, 2009 8:03 pm
by sax player
have just purchased a tvr 4ltr griff engine. The engine numbers correspond to a griff engine however is there an easy way to prove i have a compression ratio of 9.8 to 1 instead of the range rover 9.35 to 1.
Also the heads are stamped etc8622 i cant find any reference to these numbers.
Finaly is there any easy way to confirm what cam is fitted.
Thank you gents.
Shaun.
Posted: Thu Jan 22, 2009 10:58 pm
by Rossco
Disco 2 and P38 Range Rover heads.
Compression is set by the piston dish so without measuring them you can't tell.
As for cam again unless you can find a number then it could be anything.
Not saying that it's not a Griff engine but who told you it was a Griff engine and what proof did they supply?
Posted: Fri Jan 23, 2009 6:14 am
by sax player
the engine numbers correspond to the tvr index and also match the log book
47a40p3567g
Posted: Fri Jan 23, 2009 8:31 am
by chodjinn
I thought Griffs were 5 litre?
Posted: Fri Jan 23, 2009 8:48 am
by r2d2hp
Griffs came in 4.0,4.3 and 5.0
Chims in 4.0,4.3,4.5 and 5.0
And dont laugh now
Tvr claimed Power
Engine BHP
4.0 240
4.3 280
4.3 BV 340 very rare between 4-20 made
4.5 285
5.0 320
Posted: Fri Jan 23, 2009 9:38 pm
by Antonyj
Rossco wrote:Disco 2 and P38 Range Rover heads.
They arent p38 heads, they are 14 bolt, not 10.
As far as the history shows the cam hasn't been changed from standard TVR fitment.
And it is a Griff engine, I took it from MY GRIFF ! HTH
