Holley with weber jets??
Posted: Tue Nov 11, 2008 11:40 pm
by Paul V8
Hello, i have heard that it is possible to fit a holley carb with a quick change jet kit which uses weber jets, is this true and if so where can i get one? is anybody using??
Thanks.
Posted: Wed Nov 12, 2008 12:27 am
by CastleMGBV8
Paul,
I'm no expert on Holley carbs but I think what you are referring to is a metering block which you can change the jets on, and have heard of these being used to upgrade Holley 390 carbs.
You may well be able to use Weber jets but these would be from the European versions such as the DCOE and IDA and not the Edelbrock/Weber which was originally a Carter and has a system of jets and needles similar to SU's.
Real Steel keep spares for Holley carbs. and would have a range of the correct type of jets
Posted: Wed Nov 12, 2008 8:46 am
by r2d2hp
They were called Weber Power Plates back in the early 80's. I bought mine from a place called Speed Unlimited in Rockville.
They were available for many versions of Holly cards but the pair I had were for the 390 as it was fitted to my capri on Swaymar maniforld.
Just checked and they were available for Models 2300,4150,4160.
Posted: Wed Nov 12, 2008 12:33 pm
by minorv8
Holley version is shown here:
http://store.summitracing.com/partdetai ... toview=sku
Then there is an Adjust-A-Jet kit:
http://www.summitracing.com/streetandst ... 3B3CEE8%7D
I could not find a link to a current version of the ancient Weber Power Plate but I have seen an article about it.
The kit that uses secondary metering block instead of a plate (making a 4160 into a 4150 type carb) is completelydifferent thing.
Posted: Thu Nov 13, 2008 6:02 pm
by Paul V8
I have already converted my carb to a 4150.
I like the look of the adjuster kit set, could i use 2 sets 1 primary and 1 secondary? looks like it would make it alot easier on the rolling road!
Posted: Thu Nov 13, 2008 6:31 pm
by JP.
It depends on the size of your engine. 3500 usualy runs on 56 primary & 58 secondairy jets so this A just a jet kit is to large for this aplication.
A good rolling road center has all the jets on stock to provide you the jets you'll need folowing the dyno sesions.
Once jetted you'll never have to change unless you'll change the setup of your engine so there's basicly no need for this fancy A-just a jet kit unless you've a high spec racing engine that needs setted by every change of weather (cold/hot/humidity) and on track conditions...............
