Page 1 of 2
Oil pressure
Posted: Tue Jan 02, 2007 7:06 pm
by JimMet
I have a 3.5l rover v8 running in my Toyota Hilux. When it is first started everything is fine, but once the engine warms up the oil pressure light comes on. My question is….Why does this happen and how do I fix it?? Any help is greatly appreciated.
Posted: Tue Jan 02, 2007 7:22 pm
by softdash3.9
I would check the oil pressure with a gauge to see where it is both hot and cold!
Rover V8's are reowned for their low oil pressure, would guess pressure is dropping as the oil heats up and viscosity changes.
Is it running on the correct grade of oil?, modern semi-synthetic/synthetic grades can lower oil pressure
It could also be due to wear in the bearings, do you know the status of your engine? just rebuilt/2nd hand unit/history unknown?
Hope the info helps
Posted: Tue Jan 02, 2007 8:40 pm
by katanaman
Make sure your using 20/50 oil.
What is the mileage on the engine?
Posted: Tue Jan 02, 2007 9:48 pm
by JimMet
As for the milage of the engine....not sure, with it not being the original engine it's difficult to tell.
I overhauled the top end but left the bottom end alone so not sure about the condition of the bearings.
At the moment it has semi synthetic 10w-40 oil in. Will that make a big difference?
Where is the best place to get an oil pressure gauge from?
Posted: Tue Jan 02, 2007 10:28 pm
by Coops
10w/40 is way too thin for the rv8 mate,
use at least 20w/50
i use fully synthetic 20w/50 in my 3.9
Posted: Tue Jan 02, 2007 10:31 pm
by ian.stewart
thev8kid wrote:10w/40 is way too thin for the rv8 mate,
use at least 20w/50
Ill go with that
Posted: Wed Jan 03, 2007 1:22 pm
Do you mean the oil light comes on at idle?, or all the time?
Posted: Thu Jan 04, 2007 7:56 pm
by JimMet
The light is on once the engine warms up at all rev ranges. I'll change the filter and put the correct oil in this weekend and let you all know what happens. Cheers
Posted: Thu Jan 04, 2007 9:41 pm
by katanaman
JimMet wrote:The light is on once the engine warms up at all rev ranges. I'll change the filter and put the correct oil in this weekend and let you all know what happens. Cheers
If its on all the time I would say you probably have a problem with the pressure relief valve sticking when the engines hot. Change the oil anyway and see what happens, if it still does it then hit the oil pump body with a rubber mallet and see if it sorts the problem. If it does your valve is sticking and you can replace it with the better designed tadpole valve. See old forum for description of this type of valve. Course you could also simply have a bad pressure sensor.
Posted: Sun Jan 07, 2007 2:37 pm
by JimMet
I put 20/50 oil in but the oil light still comes on.
I tried hitting the pump to see if it would release the potentially sticking valve but it had no effect.
Would it be worth replacing the valve with a tadpole one just to see if it has an effect?? If so where is a good place to get one from and how easy is it to fit?
Posted: Sun Jan 07, 2007 6:58 pm
by katanaman
only one place i know of sells them and that's JE engineering. you could take the pump base off and see if he valve is stuck.
Posted: Sun Jan 07, 2007 7:17 pm
by jrv8
Hi ,
Are you sure that it's not a faulty oil pressure switch. It would be unusual for the light to be off when cold and then on when warm, even when revved.
Are the tappets noisy when the light is on ?
Jim
Posted: Sun Jan 07, 2007 7:59 pm
by JimMet
I'll take the pump base off like katanaman said and see if the valve is stuck.
The tappets make no noise at all.
Posted: Sun Jan 07, 2007 10:03 pm
by katanaman
if the tappets aren't making any noise then try Jim's suggestion first.
Posted: Tue Jan 16, 2007 8:24 pm
by JimMet
Sorry to need to be spoon fed on this one but......
Is the oil pressure switch the thin piece with 3 spade connectors on the end that comes out of the oil pump casing or is it the shallow cylinder that's about 2 inches in diameter and about 1 inch deep?
Neither have wires going to them.
When it comes to replacing the oil pressure switch is it as simple as screwing the old one out and replacing with the new?
