wild cat stage 1 head price?
Posted: Sun Sep 07, 2008 6:43 pm
by kokkolanpoika
Hi..
Just want to know does anyone know price of wild cat stage 1 heads?
+ do i need wild cat inlet manifod too? Or is it possible to fit OE rover manifold?
7500AUD + 6800AUD manifold.. = 6478£?? Is this true??
http://www.triumphroverspares.com.au/pa ... rent3id=20
Posted: Sun Sep 07, 2008 9:04 pm
by russell_ram
I was under the impression that they were roughly £2500 but I could be very wrong. Not sure if that includes the rocker gear (individual stud mount roller rockers) and rocker covers (old buick fixing pattern). Both are totally different to std rover stuff. As for inlet manifold, if you want a 4 brl one then you can use a std rover part with spacer plates but they ports will be badly mismatched - both in size and height up the side of the headface (to straighted the runners) - even the stage 1 W/C ports make even stage 4 rover head ports look tiny. You'll also need new/modified exhaust manifolds because again the ports are much higher on the side of the head which straightens up the exhaust port runners.
Why not phone Ian direct?
http://www.roverv8engine.co.uk/index2.htm
I can post some comparative pictures if you like.
Russ
Posted: Sun Sep 07, 2008 10:23 pm
by HairbearTE
Given the cosiderable investment required to go with wildcat heads I would suggest it would absurd to then try to adapt any standard inlet to fit. I personally have never seen a wildcat rover that didn't run either the wildact downdraught EFI inlet or a custom made piece.
Posted: Thu Sep 11, 2008 12:18 pm
by CastleMGBV8
Just seen on the British V8 board in the US that TA Performance are going to manufacture heads for the Buick (Rover) based on their very sucessful V6 heads and the suggested price is $2500 a pair.
They should be available next year.
Posted: Thu Sep 11, 2008 1:45 pm
by JP.
CastleMGBV8 wrote:and the suggested price is $2500 a pair.
Thats about the same price the Merlin heads are.
Posted: Thu Sep 11, 2008 2:47 pm
by chodjinn
I'm assuming that $2.5k does not include shipping or taxes?? Be interesting to see what valve size etc they are gonna use
Posted: Thu Sep 11, 2008 2:57 pm
by Greg55_99
chodjinn wrote:I'm assuming that $2.5k does not include shipping or taxes?? Be interesting to see what valve size etc they are gonna use
These are the heads they will be putting out (with one more cylinder).
http://www.taperformance.com/proddetail ... 0%5FSI%2DA
Very tastey....
Greg[/img]
Posted: Thu Sep 11, 2008 3:02 pm
by chodjinn
Power Potential: Will support up to 1000 HP (1)
Valves Int./Exh: 1.940 / 1.600
CFM (base) Int./Exh: 211 / 166 .500” Lift
CFM (max) Int./Exh: 247 / 195 @ .550” Lift
Chamber CC’s: 46
Runner CC’s Int/Exh: 156 / 72
Ok you sold me, I want some of those bad boys!!! 8)
Posted: Thu Sep 11, 2008 3:12 pm
by Greg55_99
chodjinn wrote:Power Potential: Will support up to 1000 HP (1)
Chamber CC’s: 46
Yeah, but those figures are with a blower. Anyway, if he says he's going to build them (and I understand he has... I'm sold...)
This is his stuff... Top shelf...
http://www.hotrod.com/techarticles/engi ... index.html
Greg
Posted: Thu Sep 11, 2008 5:34 pm
by v8 jago
When i asked ian about some stage 1 and a wildcat inlet manifold to fit the heads he quoted me £2100 but the price might go up a little but i wouldnt think it would be more than £2200. The only thing is he isnt in a rush to get jobs done. When i was getting my bottom end from him he told me a few weeks and he was going to put pockets in the pistons while building it so when i come to buy wildcat heads they would just fit streight on. I begged for my engine back after 4+ months and said the pockets could wait but i couldnt anymore. I had problems with the first crank after only 70 miles, So he sorted another one out for me and it only took him another 4 -5 months to get it machined. Very nice bloke who pushes your patience to the limit and futher, Or maybe very laid back or laid down maybe :lol:
Posted: Thu Sep 11, 2008 7:09 pm
by chodjinn
lol sounds like a certain enigne builder that i used to know :roll:
Posted: Tue Sep 16, 2008 2:16 pm
by Wotland
May be I am wrong but this heads have been designed for 3.8'' bore.
Ultra big valves with good seat design increase low lift flow who is a major influence on the shape of the power curve after peak power.
But here majority uses 3.7'' bore. How shrouding factor will now affect low lift flow figures ?
IMO that 's why RS doesn't sell Merlin heads for 3.5'' bore.
