Which carb?
Posted: Fri Aug 15, 2008 6:53 pm
by Paul V8
Hello, I have a 3.5 rover V8, its got a 10.5:1 comp ratio, crowler 50232 cam, rhoads lifters and worked heads. At the moment im using a 390 holley, im about to set it up but before i do am i using the correct carb? is it to small, would i be better off with a 465 or even a 600cfm? id like to stick with holley.
Thanks.
Posted: Fri Aug 15, 2008 7:12 pm
by sidecar
The 390 holley seems to be the holley that people fit to a 3.5. The other one is the Weber/carter/edelbrock 500. I think that you can use the bigger edelbrock because the primaries are actually smaller than the ones on the holley. This stops the thing bogging at low revs.
I think that the bigger holleys will give you some problems! (AJMHO)
Pete
Posted: Fri Aug 15, 2008 8:40 pm
by RoverP6B
Yes you don't want to go for a carb larger than 390 that you are currently using, otherwise as Pete said, you will have problems.
Less throttle response, less torque where you need it, less acceleration off the line, and more fuel consumption.
Stick with the 390cfm!
Ron.
Posted: Sat Aug 16, 2008 10:33 am
by CastleMGBV8
Paul,
If the Holley is in good condition and set up correctly for your engine I would stick with it.
If the Holley needs recalibrating for your current engine spec then I would recommend changing to the Edelbrock 1404 500cfm, it's a very efficient carb and very easy to re- calibrate and can return some quite good MPG figures, my mildly tuned 3.5 approx 200 BHP returned approx 26MPG on a journey of around 200 miles which is relevent with the current price of fuel! They can be sourced from Summit in the states for approx $260 which should equate to approx £180 delivered in the uk. all the rods and jets are available from RPI
I have recently built a new 4.35 engine and have also installed the crower 50232 so am wondering how it performs in your engine, it will be a little milder because of my larger capacity so am hoping it will still be reasonable on the road when I eventually get the engine fitted.
Posted: Sat Aug 16, 2008 2:14 pm
by Paul V8
Thanks for replys.
The crowler 50232 seems ok, im using the rhoads lifters. I was told that the cam would give a lumpy idle but its fine, idles smoothly at 850rpm and is no problem in traffic. I'm still running the engine in so being careful
Should visit a rolling road soon so will find out what is got.
