Page 1 of 4
Stroking a 3.5
Posted: Tue Jul 29, 2008 2:40 pm
by chodjinn
Looking at options to increase the displacement of a 3.5 block without changing the liners. I'm info'd up on larger capacity blocks etc as Gav was looking into it a yr or so ago, but not too sure about the small bore block.
So, stroker cranks? What if I fitted a TVR 5 litre crank, would that give me 4.4litres?
And how available are the old 4.2/4.8 cranks?
Only thinking about increasing displacement as the turbo I've just got has a rather large exhaust housing and it'll need all the help i can give it to get it spooling
cheers
Posted: Tue Jul 29, 2008 3:30 pm
From memory there are buick/holden leyland australia cranks that give 4.4 litres with a 3.5 bore, there is also a stroker crank set up sold (I think still sold) by Real steel that gives 4.3 litres with a 3.5 bore. 4.6 litre crank will need the mains turning down but again should be possable to do (not sure about oil pump for this) 4.2 crank I don't know enough about. beyond that I have seen crank blanks for sale around the place (I think boosted had some a while ago) that you can machine to about 96 mm throw.
If you want to get exotic then there are various NASCAR chevy rods with small big end sizes that with some suitable pistons or little end bushes would let you off set grind the standard crank a bit.
Posted: Tue Jul 29, 2008 4:03 pm
by Wotland
Real Steel sold in the past an 4.3 stroker for 3.5 block :
There is also the buick 300 crank alternative :
I think V8Tuner has one 86mm stroke crank for small journal block.
Posted: Tue Jul 29, 2008 4:08 pm
by Wotland
Posted: Tue Jul 29, 2008 6:52 pm
by chodjinn
Hmm, well I already have the rods and hopefully pistons soon and can't afford to change them. The buick 300 crank and P76 would have to be machined along with a few other bits.
If I got the mains turned down on a 4.6 with, say 3.5 rods and pistons what capacity would that be?
Same question with the TVR 5 litre crank, which should bolt straight in as is, but give less than 5litres? Think a new crank is out of my budget really
Posted: Tue Jul 29, 2008 7:19 pm
by Wotland
In theory :
4.6 crank (82mm stroke) with 3.5 bore : 4072cc
TVR 5.0 crank (90mm stroke) with 3.5 bore : 4469cc
Posted: Tue Jul 29, 2008 7:30 pm
by chodjinn
That's more like it, cheers! Hmm, question is, would the 5litre crank take abuse given its penchant for breakage, maybe if it were nitrided/tuftrided? Could get it cross drilled as well, and radius'd oil holes . . .
Posted: Tue Jul 29, 2008 7:46 pm
by katanaman
not sure about this at all but I seem to remember the tvr crank didnt use standard sized journals. I seem to remember demo saying something about that when he was building his motor.
Posted: Tue Jul 29, 2008 8:04 pm
by Wotland
Pretty sure TVR 500 crank have 2.3'' small main journals as they didn't use X-Bolted block.
Posted: Tue Jul 29, 2008 8:10 pm
by chodjinn
It would be handy if they were 2.3" as I already have a set of 77 bearings spare
Posted: Tue Jul 29, 2008 8:14 pm
by katanaman
no they didnt use cross bolt block but they did use the intermediate block with the closed mains. The size wasn't small or large journal anyway it was unique to TVR as the cranks were. Could be completely wrong here but it is in the back of my mind they were different for some reason.
Posted: Wed Jul 30, 2008 10:38 am
by TVRleigh
chodjinn wrote:Hmm, well I already have the rods and hopefully pistons soon and can't afford to change them. The buick 300 crank and P76 would have to be machined along with a few other bits.
You would be better off selling the TVR 5ltr crank, than re-grinding it.
The money you would save on the re-grind and the sale of the TVR crank, you could by the stuff you need and may even have change.
Posted: Wed Jul 30, 2008 11:13 am
by chodjinn
I dont have a 5 litre crank?! I haven't got any at the moment, apart from two standard 3.5s . . .
Posted: Wed Jul 30, 2008 2:44 pm
by TVRleigh
chodjinn wrote:I dont have a 5 litre crank?! I haven't got any at the moment, apart from two standard 3.5s . . .
Ok, I would not even think about trying to get one,
You could get a Complete S/H 3.9 Engine for the price of a 5ltr crank.
Posted: Wed Jul 30, 2008 4:23 pm
by chodjinn
true, but i dont want a second hand 3.9 bag of poop because it wouldn't last five seconds. TVR cranks have gone for little in the past; even DJE is selling one at under £500 right now, but I wont deal with him period.
Its looking increasingly like I'll stick with a 3.5 crank, maybe a group A spec one or equivalent (been offered a Group A crank for £350 but I think that is a bit too much!), and make a revvy little basta'd and sling in some nitrous to help spool the turbo up. For the price of a stroker crank, I could get a nice nitrous system . . . oh dear evil thoughts lol.
Water/methanol injection is also on the shopping list.
As is either a bigger intercooler, or swapping it out for a chargecooler. All a long way away, but food for thought none the less.
