Distributor regraphing for a 4.6
Posted: Tue Jun 24, 2008 10:41 am
Some 18 years ago, I purchased a new Lucas 35D8 distributor, then as a spare for my 3.5 in the P6B. As it would come to pass, this distributor was to find iteslf a home in my new 4.6.
Given that the characteristics of both engines are different, the distributor had to be regraphed so as to meet those new requirments.
The rate of and total advance must meet the requirements of the engine in question. I do know that the primary and secondary springs within the distributor were changed, and that prior to regraphing the maximum advance as applicable for the 3.5 in the P6B was 30 degrees at the crankshaft @ 4800rpm.
For the 4.6, maximum advance is brought forward, and now occurs at 3700rpm. The exact amount though I am not sure of.
It is my understanding that the combination of ignition advance and air fuel ratio adjustment from off idle to red line will provide in essence the maximum engine performance in terms of torque and power at all points within that band.
Ron.
Ron.
