valve to piston clearance
Posted: Sun Jun 08, 2008 3:01 pm
I've just fitted a new set of pistons to the 4.6. These ones dont have the valve cutouts. I've fitted one head back on with all the rods etc back in the right positions. I've fitted some test springs to the valves as well. With each piston at TDC on that bank, I get (as best as I can measure with the vernier) 2mm of movement if I push the inlet valve down by hand until it hits the piston. This is the amount of play with the lifter fully extended so none of this movement is pre load. My understanding is a safe min clearance of 60 thou. I seem to have 79thou.
Is this going to be enough to allow for expansion etc?
Perry
Perry
