New 4.35 Engine
Posted: Thu May 29, 2008 5:56 pm
by CastleMGBV8
At last after being delayed by Real Steel for over two months on the balancing the bottom end is now together.
The heads should be completed tomorrow and bolted on so we can measure the valve gear and decide on pushrod length.
The sump is yet to be painted!
Here's a picture I hope.
Kevin
Posted: Thu May 29, 2008 6:03 pm
by Coops
Here you go mate,
thats a sweet engine you got there mate,
Posted: Thu May 29, 2008 6:26 pm
by CastleMGBV8
Thanks Tony
How do you post the picture attached to the text.
Kevin
Posted: Thu May 29, 2008 8:00 pm
by katanaman
thats some serious cutting for the valves there.
Posted: Fri May 30, 2008 7:26 am
Sticking with tin head gaskets?
Posted: Fri May 30, 2008 8:15 am
by CastleMGBV8
Chris,
The Heads are Buick 300 and originally had 54cc chambers, we have machined the heads to reduce the chamber size to 49cc and with the Chevy pistons and tin gaskets that should give me a c/r of approx 9.8/1. If I use composites it will drop back to approx 9.4/1
Posted: Mon Jun 02, 2008 7:02 pm
by Coops
CastleMGBV8 wrote:Thanks Tony
Kevin
if you mean how did i get the image to show, i have edited your original post so you can see how its done mate,
