Page 1 of 2
What silencers?
Posted: Sun May 25, 2008 10:41 am
by Chorlton
What silencers would people recomend to get a kitcar with and RV8 through an SVA ??
Posted: Sun May 25, 2008 11:05 am
What kit car are you building? what space do you have? Rover engine?
Ideal set up is two box small front box about 10 to 12 inches long 4 1/2 to 6 inch diamiter after the header (run the engine on open headers with a length of straight stainless steel pipe on and look for where the pipe gets hottest that is where you want the first box to start). second box wants to be at least 18" further down about 12 to 18 inches long and ovel 4.5 by 8 inches. this is assuming a 3.9/ 4.0 rover on 2.5 bore pipe, all boxes straight through. I have seen these at stoneliegh a few weeks ago, Aeroexhaust.com (they have a UK distributer who I cant't find at the moment but I'll post it up when I find it) not used them myself yet but their boxes are what I am planning to put on mine when I get to that point.
Posted: Sun May 25, 2008 11:32 am
by Chorlton
My apologies.
Its for a GCS Morgan replica, so exhausts would have to be fitted each side with the silencer box tucked under the running boards.
Ive got block hugger manifolds and the single outlet at the base is quite small.
Posted: Sun May 25, 2008 7:19 pm
by mgbv8
I use the Chevy Turbo mufflers from RS. They are flat oval and about 10" wide by 4" deep and about 14" long.
They are only about 30 quid each and they are all I use on mine. My MOT man is happy with them too.
Posted: Sun May 25, 2008 7:25 pm
by ian.stewart
Ive got a single flowmaster, but I cant Imagine it ever been able to pass the SVA
Posted: Mon May 26, 2008 9:28 am
by Chorlton
mgbv8 wrote:I use the Chevy Turbo mufflers from RS. They are flat oval and about 10" wide by 4" deep and about 14" long.
I can find lots of references for RS on Google but no UK dealer.
Got an address or website please?
Posted: Mon May 26, 2008 10:04 am
by mgbv8
Sorry mate
RS is Real Steel in Uxbridge. Not RS components.
The mufflers are on page 115 of the book. Not sure about the new website. Enjoy
Posted: Mon May 26, 2008 1:10 pm
by katanaman
Posted: Mon May 26, 2008 2:16 pm
by mgbv8
Thanks Marki
I thought I had attched that link. Was in a hurry as Dave Tetlow turned u as I was typing.
I've had a flick around the RS site. Its a bit slow to navigate isnt it??
Perry
Posted: Wed May 28, 2008 12:17 pm
by Chorlton
Many thanks
Cant find them on the website so will have to get hold of the their proper lists
Posted: Wed May 28, 2008 1:10 pm
by mgbv8
I think the website must still be under construction.
The budget mufflers I use are still about 20 quid each inc vat for 2.5 inch connections.
Posted: Sat May 31, 2008 7:11 pm
by Ian Anderson
SVA
Well there is something that I went through and it does not remind me of happy times!
We went LOUD at first test (105db at 2000rpm) but free flowing so the emissions were real easy
They then failed the car on the noise
We adjusted the exhaust and inserted extra baffles etc and it passed - they can only recheck the failed items at the retest.
So give them something to get their teeth into and fail you and then fix it afterwards for the retest.
Posted: Sun Jun 01, 2008 11:08 am
by Chorlton
Thanks for that. Im still trying to get hold of those RS Mufflers though
Posted: Wed Aug 13, 2008 11:14 am
by topcatcustom
kiwicar wrote:What kit car are you building? what space do you have? Rover engine?
What makes it an ideal set up? I will be doing something very similar but won't have to SVA it so noise isnt sooo much of an issue - however I'd rather let the power do the talking than the exhaust note... until I put my foot down anyway!!!
I want twin pipes down the sills (1 each side) and exit before back wheel so will need very small or long thin silencers- what is going to be most efficient?
Thanks!
Posted: Wed Aug 13, 2008 12:50 pm
for a V8 you want either a 4:2:1 or a 4:1 long tube set up with a ballance pipe or a full "cross over" set up that goes 8:2:1:2 where the middle two pipes on each side are merged with the outer two on the other (really only possable with a mid engined car) the actual system should be straight through and have a constant diamiter after the first box. Two boxes on each side with the first about 1/4 to 1/3 the volume of the second, ballance pipe at the first "blue striping" (band on the pipe where it resonates and gets hot) after the pipes merge at the collector, first box starts the same distance on from the ballance pipe as the ballance pipe is beyond the collector ballance pipe should be about 3/4 the diamiter of the main exhaust and and idealy a whole number of times the volume of one cylinder. The last box is "stuck on the end as far down as you can go"
Apart from that the principle is minimal bends, straight through pipes and constant pipe diamiters (unless you know what you are aiming to achieve).
