Page 1 of 2
heater hose?? Serp cover/pump??
Posted: Mon Dec 18, 2006 2:35 pm
by ihatesissycars
I've come up to a problem and i'm struggling for a solution.
I've changed to a 3.9 serp front cover etc and i don't know where to put my heater hoses!
The pump hase no small inlets or outlets other than for the bottom hose.
The manifold has one thats heater hose size, this on the engine side of the thermostat so i could use that one but i've no idea where to put the other. Maybe a t junction into the bottom hose? I'm stumped!
Posted: Mon Dec 18, 2006 3:43 pm
by katanaman
is it not a flow and return for the heater circuit?
Posted: Mon Dec 18, 2006 4:59 pm
by ihatesissycars
It is a flow and return for the heater i need to plumb in but i have only one union available. The inlet manifolds is a hotwire one and doesn't have the pipe work under the manifold and teh front cover/pump has not extra unions on it either.
Posted: Mon Dec 18, 2006 5:16 pm
by katanaman
Some of the original installs has two metal pipes that run down the top drivers side of the engine between the plenum and the rocker cover. It also has a handy filling point in it too making it easier to get air out the system so might be worth trying to find one.
Posted: Mon Dec 18, 2006 5:27 pm
by ihatesissycars
Yes i've seen the metal pipes but they only direct the water to somewhere, where is that?
One goes to the manifold before the stat but its the other one? On tvr's it dissapears down the drivers side of the block but i've not found a piccie of where precisely.
Posted: Mon Dec 18, 2006 8:05 pm
by katanaman
goes to heater
Posted: Mon Dec 18, 2006 8:10 pm
by Coops
goes from manifold through one metal pipe to the heater, then from the heater through the other metal pipe to the pump.
Posted: Mon Dec 18, 2006 8:57 pm
by ihatesissycars
I think i'm misunderstood, about the pipes that is. . .
I only have one union on the engine so i have a coolant feed for the heater but no where for the heater return on the engine. Thats the problem, no where for the heater return to go.
Posted: Mon Dec 18, 2006 9:10 pm
by Coops
has the water pump got a heater hose size stubb mate?
Posted: Mon Dec 18, 2006 9:15 pm
by ihatesissycars
Nope. The oinly stub/union etc is the one on the manifold. There is another on the manifold but if i put the heater to and from the manifold the pump won't have any effect on water flow thru the heater so can't use that.
Posted: Mon Dec 18, 2006 11:07 pm
by katanaman
No idea about this but is it possible the serp front needs the gems inlet to sort the plumbing? Some pics might help too.
Posted: Mon Dec 18, 2006 11:12 pm
by ihatesissycars
i'll try and get some pics asap.
The front end i'm using was from a hotwire equipped interim 3.9.
Posted: Mon Dec 18, 2006 11:16 pm
by katanaman
Hopefully Roysten will see this as that's what he is running. Its still poss for it to be a diff inlet mind you to the usual hotwire.
Posted: Wed Dec 20, 2006 5:18 pm
by ihatesissycars
Solved!
One goes to the manifold as i suspected but the other goes to the bottom hose to a (in my case) tee piece or to the rad near the bottom hose!
Posted: Wed Dec 20, 2006 6:40 pm
by Coops
nice one gav
