Overhauling Lockheed brake booster
Posted: Thu Apr 24, 2008 10:47 am
by RoverP6B
I am in the process of overhauling my spare brake booster for my Rover P6B.
The slave cylinder has been previously resleeved, and I have the genuine Lockheed kit for the complete assembly.
My question though relates to the condition inside the vacuum chamber.
The was quite an amount of corrosion which has now been removed, but I fear that if I leave the surface bare without any form of protective coating, the same will happen again.
Should the inside surface be painted? If so, what type of paint is resistant to brake fluid? Or should the surface just be left bare metal?
Any thoughts wil be highly appreciated.
Ron.
Posted: Thu Apr 24, 2008 12:21 pm
If I was being a perfectionist, I'd try to get it plated rather than painted.
Posted: Thu Apr 24, 2008 12:41 pm
by RoverP6B
Hello Chris,
By plated do you mean chrome plated?
I have also seen brake calipers advised as having been plated.
Ron.
Posted: Thu Apr 24, 2008 1:38 pm
if you can heat the relevent bits, I would get it stove enamaled (not powder coated), I can't think of many things that resist brake fluid but stove enamaling is one. Just remember the surface is not as mechanically tough as powder coating.
Posted: Thu Apr 24, 2008 2:42 pm
I meant Cadmium plating, that kind of goldy colour that these things often have when new.
