Help Please! Problem with ABS ECU on Range Rover
Posted: Sat Dec 16, 2006 12:44 pm
I wondered if anyone can help me with some advice on my 94 Classic 3.9 SE.
For a couple of weeks now, the ABS & ETC warning lights have been staying on all the time. The other brake light goes out as normal. The brakes feel fine but I haven't bothering jumping on the brakes or accelerator to see if the ABS & ETC circuits are working properly.
The car went in for its MOT this week and failed only on the fact that the ABS light won't go out. When they connected a code reader to the car, they said that they could see the other ECUs on the car but couldn't interrogate the ABS ECU. Their initial diagnosis is that the ABS ECU has failed in some way, causing the lights to stay on.
So any ideas where I should start? Most of the diag routines in the manual are based on being able to put a connector in between the ECU plug lead and the ECU itself, and then use a multimeter on various pins. I don't know where I could get one of those connectors at short notice. Are there any other tests that I can easily do to see if power and earth circuits are working on the ECU, for example? Are the ABS ECUs prone to failing, could I dismantle it and just spray it with contact cleaner to cure any dry joints?
Any ideas gratefully received. The MOT expired today, so I'm now off the road until I can fix this!
Tks
Paul
Tks
Paul
