Fuel rail thingy
Posted: Wed Mar 26, 2008 12:46 pm
by chodjinn
There is a connection on my fuel rail and I don't know what it's for. Its on the left hand side, looking from the front of the engine.
Looks like something screws onto it? Its quite small, and has some ptfe remains on it.
Any ideas?
Posted: Wed Mar 26, 2008 4:13 pm
fuel pressure gauge?
Posted: Wed Mar 26, 2008 4:42 pm
by r2d2hp
Or is it the fuel rail temp sensor.
Posted: Wed Mar 26, 2008 5:28 pm
by chodjinn
well it's not the fuel rail temp sensor as that's on the other side and has a connector like an injector/sensor etc, so must be a fuel pressure thing?
Either way i don't need it for anything (have a fuel pressure gauge on my adjustable regulator), can I just put a bung on it?
thanks
Posted: Wed Apr 02, 2008 3:49 pm
by jwriyadh
The outlet is threaded internally and externally.
Don't bung it, fit a schrader valve.
The latest Disco 1 with a 3.9 Hotwire and Serp frontend had this fitting on the fuel rail to simply measurement of the fuel pressure.
Warnings.
Do not know if the schrader has a special spec because of petrol contact. It would be worth checking.....somewhere. A LR dealer could supply an appropriate grade replacement.
When you use it for pressure measurement use a good quality screw-on connector, not a clip-on.
jw
