35D8 Exploded Parts Diagram on the web
Posted: Mon Feb 25, 2008 10:17 pm
by Stoat
Hi there,
Does anyone know if there is a exploded parts diagram for the 35D8 dissy on the net?
My vacuum advance appears to have "disconnected" and I'd like to know what I should expect to see before I start stripping :-}
Stoat
Posted: Mon Feb 25, 2008 11:46 pm
by CastleMGBV8
It's probably the diaphram in the vacuum can you can test it by sucking the tube and if there's no resistance you need a new one.
There available from Rimmer Bros for an exorbitant £40.
Not a diaphram...
Posted: Thu Feb 28, 2008 5:28 pm
by Stoat
Tried that, when I suck, the lever moves but the baseplate doesn't.
Stoat
Re: Not a diaphram...
Posted: Thu Feb 28, 2008 10:52 pm
by jrv8
Stoat wrote:Tried that, when I suck, the lever moves but the baseplate doesn't.
Stoat
Hi ,
There's two different types of points for the 35 D8.
One type has a peg on the bottom that engages the vacuum advance lever. The other type doesn't.
Could you have the wrong type of points fitted ?
Regards
Jim
Ahhhhh!
Posted: Fri Feb 29, 2008 6:04 pm
by Stoat
I think this problem started when I converted it to a Lumenition electronic system...............
I'll pull the distributor out and have a look.
