revs wont come down
Posted: Sat Feb 16, 2008 8:16 pm
by murf
hello my 1985 range rover is messing me about .engine revs to hight when its warmed up it has solex carbs and points dizzy .tryed turning tick over down but engine dies when you put it in gear 3 speed outo all so when you put any electics on ie lights /fan revs drop please help :cry:
Posted: Sat Feb 16, 2008 8:21 pm
by katanaman
check for air leaks
Posted: Sat Feb 16, 2008 8:25 pm
by murf
hello man dun that all i found was a split pipe from dizzy to carb replced that made no diferance thans
Posted: Sat Feb 16, 2008 8:31 pm
by katanaman
Have you sprayed round the inlet joints to the head an all that with wd40 or something? Sorry if you have already done this but its quite common for the gasket to leak here.
Posted: Sat Feb 16, 2008 8:37 pm
by murf
no i only sprayed around the carbs ill give that ago tomorow thanks
Posted: Sat Feb 16, 2008 8:59 pm
by CastleMGBV8
On the solex carbs the rubber diaphrams in the dashpots quite often rot and could be causing your problem.
Posted: Sat Feb 16, 2008 9:03 pm
by murf
ok thanks il check them as well .doe you know if su carbs will fit thanks
Posted: Sat Feb 16, 2008 10:38 pm
by CastleMGBV8
The SU carbs should be a straight swap.
Posted: Sat Feb 16, 2008 10:52 pm
by murf
ok thanks
