Oil filter design
Posted: Tue Feb 12, 2008 10:14 am
Some oil filters are designed with an inbuilt pressure relief valve, brought into operation when the difference between the oil pressure entering the filter and that leaving the filter exceeds a pre determined level. Oil thus bypasses the filter media, returning to the engine unfiltered.
Other oil filters have no such inbuilt feature.
Of these two designs, is one preferable to use with the RV8, and if so why?
I note that there is a filter bypass inbuilt into the oil pump front covers, as fitted to the P6B. Does this make the use of the former and it's inbuilt relief valve redundant?
Ron.
Ron.
