Chevy flywheel weight
Posted: Sat Dec 29, 2007 12:26 pm
Hi all
as the heading says this is a question about chevy flywheel weight. I have a flywheel for an externally ballanced chevy, it came as part of the kit to fit the Chevy to the audi gearbox I have.
Owing to a change of plan I need an internally ballanced flywheel (can't fit in catalitic converters so I have built the engine around a 74 block rather than the '98 block I started with) so I either need to re ballance the flywheel (ie drill 12 holes to 1/2 inch deep opposite the ones already in the flywheel) or get a new flywheel made.
The existing flywheel is 28lbs and is 10.75 inches in diamiter and is to take a 4.2 litre A8 clutch making a set up of about 35 lbs ie heavy!
The engine is intended to rev to about 7800 so the thoughts are that this is probably not ideal.
The alternative therefor is to get one made up in ally with a tilton multiplate clutch and a steel clutch face and use the custom ring gear off the flywheel off the kit.
I would welcome thoughts and comments as I don't really want to fork out for a custom clutch if I can use the one I've got (with modification).
The set up will be used with a 6.25 inch fluid damper (space at the front of the engine is limited.
