Best thing for blocking up Plenum holes with?!?
Posted: Wed Dec 06, 2006 6:06 pm
by chodjinn
Yeah, daft question I know, but I have about five holes to block up on my plenum chamber, (including the vaccum for the dizzy, the two large pipe connections under the throttle and the brake servo connection - all not being used).
I was thinking of some metal epoxy stuff like araldite but can't remember the name of it. I'm also a bit worried about heat resistance - especially as the engine is turbo'd.
Any suggestions?
thanks
Posted: Wed Dec 06, 2006 6:26 pm
by softdash3.9
You're probably thinking about JB Weld.
As regards the Servo holes could you not fit a solid bolt? instead of the banjo type
Posted: Wed Dec 06, 2006 6:39 pm
by ihatesissycars
I've used the liquid metal as you've mentioned for mine.
Did you get that fuel filter? Any good?
Posted: Wed Dec 06, 2006 6:55 pm
by Kev
You can ignore the 2 large pipes under the throttle, they deliver hot water under the plenum and don't go anywhere. I've removed the heater plate from mine so they're not on the plenum now. If you do remove the plate you'll need to plug the two inner holes as they're in the plenum post throttle.
Kev
Posted: Wed Dec 06, 2006 8:45 pm
by Eliot
Kev wrote: If you do remove the plate you'll need to plug the two inner holes as they're in the plenum post throttle.
Kev
Which i discovered whilst trying to work out why a newly built rv8 wouldn't tick over or run right.
Posted: Fri Dec 08, 2006 9:41 am
by chodjinn
sorry the plate thing has been removed, I meant the two pipes that go out at right angles pre-throttle plate - I think they are for the extra air stuff?
And yeah Gav, filter looks great! Just gotta get me a swirl pot and som high pressure fuel lines . . . and the rest of the bits for the engine!
