Plugs fouling
Posted: Tue Nov 27, 2007 6:39 pm
by acs
I have recently converted my 90 from a 3.5 to a 3.9 Efi.
The 3.9Efi I fitted had been sitting around for a few years not exactly sure how many.
Anyway the plugs keep getting fouled with black oil type goo.
My thoughts would be the valve seals are shot from standing round too long without oil.
Before I take the heads off do you think I'm chasing the right thing or should I be looking else where
Thanks in advance
Adi
Posted: Tue Nov 27, 2007 7:25 pm
by Coops
if they are getting that fouled up i would be suspect of rings possibly.
Posted: Tue Nov 27, 2007 7:28 pm
by acs
They get fouled to the point where the engine doesn't start and I have to clean all the plugs.
The fact it was across all the cylinders I was hoping it might have been the rubber seals.
I was scared incase it's the rings.
Adi
Posted: Tue Nov 27, 2007 7:42 pm
by Coops
do a compression test.
Posted: Tue Nov 27, 2007 7:48 pm
by acs
They didn't seem to be too bad. Well at least fairly consistant
7: 143 8: 152
5: 150 6: 154
3: 157 4: 160
1: 153 2: 157
Posted: Tue Nov 27, 2007 8:06 pm
by ian.stewart
Are the plugs just wet and old, It may just be sticky rings, Have you tried new plugs and check the gaps, if it is stickey rings it could be worth squirting WD40 or Diesel down the plugholes and leaving for a few days, and turning the engine over every now and then with the plugs out.
Ian :D
Posted: Tue Nov 27, 2007 8:09 pm
by katanaman
No 7 is fairly poor, the diff between the lowest and highest should be no more than 10%. Its easy to find out if the compression is caused by bad rings tho as you add oil to the pistons and if the compression comes up its rings, if it doesn't its valves. Could well be your valves are all gummed up and not seating properly. If your plugs are getting that fouled I would expect the engine to be fairly smokey. When does it smoke the most? Valve guide seals would normally smoke most on the overrun.
Posted: Tue Nov 27, 2007 8:21 pm
by acs
ian.stewart wrote:Are the plugs just wet and old, It may just be sticky rings, Have you tried new plugs and check the gaps, if it is stickey rings it could be worth squirting WD40 or Diesel down the plugholes and leaving for a few days, and turning the engine over every now and then with the plugs out.
Ian :D
I'm on my 3rd set of plugs now. Gapped each time they go in.
Haven't tried WD40 but sounds worth a try before the engine comes back out.
Adi
Posted: Tue Nov 27, 2007 8:24 pm
by acs
katanaman wrote:No 7 is fairly poor, the diff between the lowest and highest should be no more than 10%. Its easy to find out if the compression is caused by bad rings tho as you add oil to the pistons and if the compression comes up its rings, if it doesn't its valves. Could well be your valves are all gummed up and not seating properly. If your plugs are getting that fouled I would expect the engine to be fairly smokey. When does it smoke the most? Valve guide seals would normally smoke most on the overrun.
It smoke worst running under load/full throttle. Tick over not a hint smoke even on startup it doesn't smoke badly.
Adi
Posted: Tue Nov 27, 2007 8:29 pm
by katanaman
Sounds to me like rings.
Posted: Tue Nov 27, 2007 8:35 pm
by acs
:( Time for another compression test
On the bright side here comes the chance to build a more torquey motor
Thanks for everyones help
Adi
Posted: Tue Nov 27, 2007 9:45 pm
by Ian Anderson
Long shot
I agree with the above and those things are well worth doing
Are you able to check your EFI is working corectly?
It could be on limp home mode and seriously overfuelling - this will bore wash and then burn sooty / oily with whatever is in the engine
If you don't have test kit disconnect the battery for 30 secs just prior to starting it - it will reset the hotwire Ecu - this may then allow enough of a run to clear the rest of the crap out and get you to running temp to "blow out the cobwebs"
Posted: Tue Nov 27, 2007 9:56 pm
by acs
Thats a good one to try.
Adi
