V8 Midget
Posted: Sun Nov 18, 2007 6:09 pm
by shetlandnick
Hi all
thought I'd better make a new thread before I get pulled for not posting for a while. Been a bit busy with the family and a house move, but hopefully the end result will be worth it. The axle goes in this week following the delivery of rear suspension nuts and bolts. The prop is already made up, so then I can work out exactly where the engine needs to sit and do the necessary cutting and fabrication. More info on
http://journals.aol.co.uk/atconick/mad-midget/ I'll be posting photos of the actual car once she's back on her wheels and able to be rolled out of the shed; maybe later this week. I know of one other V8 midget on the way (got the axle, prop and wheels of that one). Anyone else know of any others being built?
Ta, Nick
Posted: Sun Nov 18, 2007 7:34 pm
by kev_the_mole
Nick,
are you going to Goodwood next year and if so you're welcome to join the "UK Nasty Boyz" group with modified Healeys and Spridgets.
If we're all together in our own little ghetto then it allows us to be more efficiently ostracized
Posted: Sun Nov 18, 2007 7:46 pm
by ian.stewart
Posted: Sun Nov 18, 2007 8:07 pm
by shetlandnick
I'm hoping to get the car mechanically sorted and legal (maybe not bodily finished) in time for Spridget 50 next May. Are you all going to that? The other V8 midget builder is hoping to have his ready by then. Be good to have a group of unfeasibly heavily modded cars there.
Posted: Sun Nov 18, 2007 8:11 pm
by Wee_chris
Any room for a V8 Spitfire?
Mine is starting to look like I'm getting there.
Local Triumph people don't like me now that I have a rover v8 and adding a Lenham front end.
Hopefully going to be roadworth by march or april, not sure about paint though
Posted: Sun Nov 18, 2007 10:56 pm
by ian.stewart
Posted: Mon Nov 19, 2007 10:10 am
by kev_the_mole
Nick and all,
Have a close look at
www.healey-weekend.com. I think some Midgets are going but Spitties and Lotii won't get in as it's a rather select gathering don'tcherknow lol:
I'm not even sure that us 'outcasts' will be allowed out of the car park.
I'm going for the chance to drive the Goodwood circuit (10 minutes track time woo-hoo) and I'm entering a mutant, rule bending rocker box because there's no fun in taking part in a competition unless you can force the rules committee to rewrite the regulations to disqualify you is there? :
Posted: Mon Nov 26, 2007 4:45 pm
by shetlandnick
Axle's in, back on it's wheels, old engine coming out this weekend.
Posted: Mon Nov 26, 2007 5:39 pm
by chrismc
Hi nick, have added your blog to my favourites.
Looks like a great project. Does the bonnet need a hump?
I mean to clear the engine!
Posted: Mon Nov 26, 2007 6:28 pm
by shetlandnick
I'm hoping it won't, but I won't know until the weekend. The plan is to have it looking like just another midget, albeit without bumpers. The other V8 Midget that I know of was using MGBGT V8 twin carbs pointing back toward the bulkhead, and that certainly had clearance problems. I think the owner is going to megasquirt it and try to get the inlet height down to minimum. I am using a JWR dual plane offy inlet and a holley 390 with a low level 14" filter, as recommended by various shops for fitting to MGBs without bonnet bulges. It is about as low as you can go with a carb setup. How it will look in a midget is anyone's guess. I may be able to drop the engine a little lower in the bay, so long as I don't have any clearance probs on the front crossmember. I may have to swap sumps from range rover to P6.
Regards, Nick
I'm the other V8 Midget builder
Posted: Tue Mar 11, 2008 11:39 pm
by mattwrigg
Hi all
Just happened to come across this forum while trying to sell Nick's old engine & box and found he had started a thread on his V8. Small world eh?
Turns out he saw a Pitts Special biplane part finished kit, he's always wanted one so rang me up and offered me all his midget stuff to clear his garage.
I acquired a mostly finished V8 midget last year from a bloke in London who had had it in his garage for a few years after buying it from the original builder. I had to build a garage to house it, and have just started proper work on it. I have stripped it and sandblasted the shell, and now just looking for someone to sort the rear end bodywork before painting and reassembly.
The engine is a standard 10.5:1 CR 3.5 Rover with Isky cam and lifters, SD1 heads and P6 manifolds. It has rear facing SU's on (Clive Wheatley manifold) which results in a hole in the bonnet to clear the dashpots. I'm trying to find a complete EFI setup to convert to Megasquirt, I'll have to shave some height of the EFI manifold and lower the trumpet height to get it under a standard bonnet. My pal tells me to get the bloody thing running and MoT'd on SU's first, then we can convert to Megasquirt later (spoilsport).
My website is
www.v8midget.com.
I hopefully should be finished this year so will try to get to some events. Definitely won't be finished for Spridget 50 in May though!
Matt
