Lt 77 Remote
Posted: Wed Nov 14, 2007 10:00 pm
by digger782
Hi all
I have finally found a “good” LT 77 but is from a Sherpa and has the short remote and I need the long one as from a SD1 has anyone got one for sale. Does anyone know which clutch I will need to fit to my SD1 V8 with this gearbox
I also need the front end of the prop shaft so I can mate it to my cortina prop, do I need any other parts?
Posted: Thu Nov 15, 2007 11:28 am
by Wee_chris
I'm sure I have a long remote in the garage, will check when I get home.
Chris
Posted: Thu Nov 15, 2007 2:05 pm
by chrismc
I have one and will swap for your sherpa one if you fancy?
Posted: Thu Nov 15, 2007 4:50 pm
by cimoss
Hi there, the clutch will be the standard 9 1/2 ", for a cheaper option you can use the drive plate from the 110 landrover as it is the same spline count and diameter....
Posted: Thu Nov 15, 2007 5:36 pm
by Wee_chris
Sorry cant find the one I had, it will be in the spaers pile in my other lock up.
Best go with chrismc
Remote
Posted: Thu Nov 15, 2007 5:55 pm
by digger782
:D Thanks Chrismc you have a PM
Posted: Thu Nov 15, 2007 7:16 pm
by chrismc
So do you! :D
Posted: Fri Nov 16, 2007 4:21 pm
by digger782
:D Thanks for the replies I am now fixed up with a remote and know which clutch the only point left is the prop shaft what connection, which prop do I need to fit my Cortina axel :roll:
Posted: Sat Nov 17, 2007 10:39 pm
by cimoss
would suggest discussing with a prop supplier, Bailey Morris in St Neots offer a superb service and good value, just had one made by them.
Look for an old prop from an SD1 / P5 this will give the correct fitment to the gearbox with the slipper joint, then it can be adjusted for length and the correct UJ on the other end...probably looking at £100 for the mods....
Posted: Sat Nov 17, 2007 10:48 pm
by JC.
They all have different gear ratios.
Are you quite sure the sherpa gearset is going to be suitable???
Remote
Posted: Sun Nov 18, 2007 5:12 pm
by digger782
I know that first will be very short apart from that i am told that the ratios are the same.
I already have a 4 speed but is no good for cruising so I need the 5th gear.
I have also been told that all I need is the flange from a sd1 prop to connect to my prop, can anyone help with this flange or any advice where i can find one (tried local scrapys )
Thanks in advance
Posted: Sun Nov 18, 2007 7:06 pm
An SD1 prop has CV joints at both ends. I suggest looking for a Land Rover prop, there's millions of different lengths, and they're dirt cheap, so you could get a 2nd hand one and use the end off that.
