Power steering hohses
Posted: Sat Oct 06, 2007 3:20 pm
by russ spake
Hi, I have a very earlier SD1 fitted in my Stag and the power steering hose has burst. I'm assuming it's the high pressure hose as it has pressure fixings at both ends whereas the second pipe doesn't.
Anyone know where I can get a hose, or make any suggesting about how I can re-attach the burst pipe end, thanks? Russ
Posted: Sat Oct 06, 2007 8:44 pm
by JSF55
Best take it to a local hydraulic hose manufacturer, check for pirtek or similar in the phone book, the other pipe is the return and isn't under pressure so it only needs a couple of jubilee clips
Posted: Mon Oct 08, 2007 7:46 am
I've used Pirtek for my Landie, very reasonably prices.
Posted: Tue Oct 09, 2007 1:30 pm
by Raggylad
Is it rubber hose or metal pipe ? Pipe can be repaired (had a similar problem recently in my V8 Land Rover) with a plumbing connector; hose needs replacing.
Posted: Tue Oct 09, 2007 2:48 pm
by r2d2hp
I use this place in High Wycombe for all my hoses
http://www.spectrum-hose.co.uk/
Very quick and helpfull people
power steering hoses
Posted: Thu Oct 18, 2007 12:14 pm
by russ spake
It's a bubber hose so I'll need to replace it, thanks for the helpful suggestions on where to go to get a new one. Russ.
Posted: Fri Oct 19, 2007 1:29 pm
Raggylad wrote:Is it rubber hose or metal pipe ? Pipe can be repaired (had a similar problem recently in my V8 Land Rover) with a plumbing connector; hose needs replacing.
Most plumbing compression style fittings, arent really rated to the sort of pressures involved in PAS systems.
Yes, I know they usually work, and have used them myself. But just be aware that they may not always work, and PAS fluid is quite flammable.
Posted: Fri Oct 19, 2007 5:15 pm
by Eliot
my local pirtec outfit was a complete clown - crushed all my fittings. :(
Posted: Mon May 05, 2008 12:25 am
by Garth84x
as were mine, got some pipes made up by pirtek, and soon as i started the car pas squirted from the pipes all over the radiator :(
garry
Posted: Mon May 05, 2008 4:35 am
Ive used Earls stuff on all my PAS hoses.
