intermitant lifter tapping
Posted: Mon Aug 20, 2007 10:18 pm
on my 3.5 RV8 if i drive at speed before the engine is fully warmed up i would get a noisy tappet/lifter, would last about 10-20 secs then stop again.
last weekend i went to MITP at santa pod, all was well going there, but coming back i would get this noisy lifter about 1/2 dozen times for no reason. this is the first time it has been driven on a long run (45 mile each way) the easiest way i found to stop it was dip cluctch and rev it up so pressure went over 3 bar.
oil is new, halfords 20/50, new filter, pressure is good, 2 bar + when cruising and its not running hot.
whats the most likely cause, might i have not shimmed the lifter preload right? or could it be a failing lifter. this engine has only done just over 800 miles from rebuild, new cam and lifters ect
