MGB V8 Starter - Coil Connection?
Posted: Sat Jul 28, 2007 1:29 pm
I am fitting a std V8 starter to my B. The previous starter was a High Torque 1.8 version and did not have the option to connect to the coil, but the starter had to be replaced as I have changed the box to a LT77.
The original wiring diagrams show a wire going from the starter directly to the coil. The supply went to the same point via a Resistor.
Is it true that this connection was so the coil voltage did not drop during cranking?
I have been runnung with out the connection but as the wire is there and the V8 starter has the output connector I though I should reconnect it.
Will this cause me any problems with the ignition module I have in the Mallory Dizzy?
Cheers.
Cheers.
