Removing the carbon ring in the top of the bore
Posted: Fri Jul 27, 2007 9:16 pm
by mrcheese
This is what I need to do when removing the pistons from a Rover V8.
I can see what needs to be removed, but what should I use to do the job?
Paul.
Posted: Fri Jul 27, 2007 9:48 pm
by ihatesissycars
Scotchbrite, light emery, carb cleaner, not bother as the rings will do it, axe, spoon, shotgun, humor, harsh language. . . . . .
No really the carbon build up isn't really that tough, it should come off with a scrape. I used some scotchbrite soaked with something like thinners or for more extreme cases a rotary wire brush on a drill will get really stubborn bits off.
Posted: Sat Jul 28, 2007 6:50 pm
by mrcheese
Scotchbrite and carb cleaner did the job nicely. It aslo takes off all the crud from the tops of the pistons.
Thanks,
Paul.
