Vacuum leak test
Posted: Wed Jun 11, 2025 7:40 pm
I’ve been having rough running at idle and smells quite rich, it has power through the range it just misfires at idle and plugs are black wet and oily. Done a vacuum leak smoke test that the only place it leaks is from under the distributor cap (not sure if that’s normal?) vacuum pressure test is 11hg so on the low side. Compression test lowest 155psi and highest 170psi. I’ve checked the sensors with a dmm and in roverguage and they all checked out. Injectors are refurbished and checked the fuel pressure 36psi when disconnected fpr and 27 when connected with engine running, also holds pressure when not running. It’s had a new ignition system with new distributor leads and plugs. I’m confused why it’s leaking from the distributor? It’s a 3.5 with a 3.9 plenum and 14cux ecu
