Valve stem oil seals
Posted: Thu Oct 20, 2022 7:48 am
Alert Newbie question......
I am rebuilding my SD1 and am about to start re-assembling the cylinder heads. When I took the heads apart there were only oil seals on one valve per cylinder (can't remember which one!) and these were not of a type I am familiar with i.e. they appeared to be rubber washers.
So the question(s)
1. Is there a better seal - I'm seen more conventional ones sold but I think my elderly heads will need new valve guides?
2. Was there only one seal per cylinder or had the other one disintegrated (hard to believe this happened on every cylinder)?
3. What do others use - just one off washer type per cylinder?
Chris
So the question(s)
Chris
