Page 1 of 2
What cam do, did, I have?
Posted: Sat Jan 15, 2022 6:26 pm
by rich112
My 4.6L ate its camshaft.
The camshaft has CML5 stamped on it. Any ideas what cam this might be?
The heads have adjustable rockers sitting on shims.
Not sure what to replace the cam with.
Cheers!
Re: What cam do, did, I have?
Posted: Sun Jan 16, 2022 8:55 am
by paul c
Have a read of the forum and search for posts on cams, lots of reading there, also try google. If you are using a distributor you will need an early cam for the drive gear, that is why I am using a 4.2 cam for mine.
Posted: Sun Jan 16, 2022 9:30 am
by paul c
You also need to know the ratio of the rocker arms if you intend to use them again, are they group A rockers or Volvo rockers that have been modified or something else? It will affect the lift of the cam so you may need a custom grind to suit.
Posted: Sun Jan 16, 2022 9:36 am
by rich112
paul c wrote: ↑Sun Jan 16, 2022 9:30 am
Yes, that's why I was hoping to replace with the same cam... I'll measure the lift on it and see if I can get something identical.
The rockers are adjustable and have oiling holes in, which means that they aren't volvo?
Posted: Sun Jan 16, 2022 11:31 am
by rich112
Some pics of the cam. Lift is about 6.8mm
Posted: Sun Jan 16, 2022 11:32 am
by rich112
And some more
Posted: Sun Jan 16, 2022 7:59 pm
by Blown v8
Give John Eales a ring, they do look a lot like the rockers he supplies,
Ask him about the cam, most engine builders have there cams ground,and number themselves
You’re going to need new followers to go with the cam, ideally the same size as you have, otherwise you will need longer/shorter pushrods.
Have a ring round to all the main suppliers,
Posted: Mon Jan 17, 2022 8:59 am
by rich112
Blown v8 wrote: ↑Sun Jan 16, 2022 7:59 pm
Will do.
I have adjustable rockers and they currently sit on shims, so the geometery isn't stock. Given that it's a 4.6l motor with a distributor drive cam, my options are limited. I just hope its not a custom ground cam! It doesn't measure as particlarly high lift but I don't know the rocker ratio.
Posted: Mon Jan 17, 2022 9:39 am
by paul c
Have you checked the installed height of the valves, if the pedestals are shimmed it may be because longer stemmed valves have been fitted.
Posted: Tue Jan 18, 2022 11:41 pm
by rich112
paul c wrote: ↑Mon Jan 17, 2022 9:39 am
Not measured the installed height yet... There are shims on the pedestals.
John Eales didn't recognize the cam code either! Very odd.
Posted: Wed Jan 19, 2022 1:35 pm
by rich112
Well it turns out the blank is made by Estas. Waiting to see if they recognize the stamped code...
Posted: Thu Feb 03, 2022 10:14 pm
by rich112
It was a stock 4.2 cam.
Bought another one from a landrover parts place, only £70.
Measured it against the old one. It's even made by the same company.
Posted: Fri Feb 04, 2022 4:44 am
by paul c
Mine has arrived eventually, and it appears to be pretty much the same as the other. They don't match the figures given from LR for the 4.2 though. I don't have a large degree wheel so not quite as accurate but still getting 117 ATDC for inlet and 113 BTDC for exhaust centrelines. Lift at lobe is 0.267"
Posted: Sat Feb 05, 2022 10:20 am
by paul c
rich112 wrote: ↑Thu Feb 03, 2022 10:14 pm
Did you check the specs of it, duration and lobe centrelines? Be interesting to see if it is the same as mine or same as the specs on Rave.
Posted: Sun Feb 06, 2022 6:45 pm
by rich112
paul c wrote: ↑Sat Feb 05, 2022 10:20 am
I have some measurements. I measured angles at every 0.5mm of lift. Not sure what's in the RAVE?
